DTH or Edge driver for Aubess Tuya Zigbee Leak / contact
Thank you. The device can be added to the hub as the moisture sensor. But the hub can’t recognize the alarm when the sensor detects water.
You wet it and it didn’t detect water?
If so, try re-pairing or rebooting the hub.
I just reboot hub and repair the device. Now it works like a charm! Thank you so much!
The following Leak Sensor have driver done by @Mariano_Colmenarejo , but I was unable to find its finger print while tying to search:
> Model : TS0207
> Manufacturer : _TZ3000_85czd6fy
I was able to find in @Mariano_Colmenarejo GitHub only…
st-zigbee-moisture-sensor-v2
Hi. Can you please add this one?
Sorry, I have no idea how to do this.
Profile - Mariano_Colmenarejo - SmartThings Community is the wizard!
Hi,
I take note to do it in the month of August, until then I do not have access to the CLI or a pc
Hi, Could you add this one as well? It shows up as a Thing, and is not picked up by a native driver.
Hi,
Added to this driver version
  • You need uninstall your device
  • Install this driver version in your Hub from my channel
  • Add device with app to pair with this driver near of your Hub to perform correct configure device
Do not perform a driver change to this driver from zigbee thing Mc
 Name         Zigbee Moisture Sensor Mc
 Version      2023-11-30T20:51:32.646215343
- id: "_TZ3000_kstbkt6a/TS0207"
    deviceLabel: TS0207 Water Sensor
    manufacturer: _TZ3000_kstbkt6a
    model: TS0207
    deviceProfileName: moisture-battery
Adds like a charm. Thank you.
Do you need a Tuya app along with Smartthings to get these Tuya water sensors working?
As long as the fingerprints are in a SmartThings Edge Driver you do NOT the Tuya app or hub.
Can you get this device to report low/no water? For example, will the sensor report water contact but switch to no water if the water level drops below the sensor?
