DTH or Edge driver for Aubess Tuya Zigbee Leak / contact
I would like to use this driver on my device (zigbee flood detector):
  • manufacturer: _TZ3000_qhozxs2b
  • model: TS0207
  • zigbeeNodeType: SLEEPY_END_DEVICE
, but I don’t know how to install it. (it only says connected)
Any suggestion would be appreciated, thank you.
I greatly appreciate your work.
Your zigbee contact mc driver helps me a lot. In addition to that, may I ask you to add one more manufacturer of β€œZigbee Moisture Sensor Mc” as below?
According to your advice regarding the tool (zigbee thing mc) for idenfiying manufacturer of TS0207,I found these strings.
Data * application: 41
  • endpointId: 01
  • manufacturer: _TZ3000_qdmnmddg
  • model: TS0207
    Raw Description 01 0104 0402 01 04 0000 000A 0500 0001 01 0019
(added: I replace capture image which contains Raw description, previous one was missing)
Thank you!!
Hi @dongouk
Added to this driver version
Driver Id 12e71b3b-184d-4b78-a0e4-679c02ca43dd
Name Zigbee Moisture Sensor Mc
Package Key st-zigbee-moisture-sensor-v2
Version 2022-10-03T09:08:06.909693223
  • id: β€œ_TZ3000_qdmnmddg-Sensor”
    deviceLabel: TS0207 Water Sensor
    model: TS0207
    deviceProfileName: moisture-battery
Thank you Mariano, I found that your edge drivers for IKEA bulbs are also very helpful to me. Thank you again! Have a great weekdays.
Sorry @Adrian_Dobrean1
I just saw this post and added your device to this driver
Version 2022-10-03T10:10:38.559106554
  • id: β€œ_TZ3000_qhozxs2b-Sensor”
    model: TS0207
To install it you have to do the following:
  • Enter the link of my shared channel
    Samsung account
  • Enroll your hub in my channel and accept the conditions
  • Go to see available drivers
  • Search for this driver by name and install it on your hub
  • Uninstall the device with the App and put it in pairing mode
  • In the App, Add new device and use the search nearby option
  • When driver find the device you will see it in unassigned room
Continuing the discussion from DTH or Edge driver for Aubess Tuya Zigbee Leak / contact:
Hi
Can you connect this water sensor?
Version 2022-10-22T15:36:08.662598929
  • id: β€œ_TZ3000_ww9i3e0y-Sensor”
    manufacturer: _TZ3000_ww9i3e0y
    model: TS0207
Any chance you could add this too?
Hi @Mang_Kanor_Lang
 Version      2022-10-30T23:07:02.096893398
  - id: "_TZ3000_ocjlo4ea-Sensor"
    manufacturer: _TZ3000_ocjlo4ea
    model: TS0207
Wow, thanks!
Hi, just came across your awesome work :slight_smile: Any chance you add this one too?
  • application: 41
  • endpointId: 01
  • manufacturer: _TZ3000_t6jriawg
  • model: TS0207
Hi @Moondevil
 Version      2022-11-28T16:49:39.605020294
  - id: "_TZ3000_t6jriawg/Sensor"
    model: TS0207
Thanks so much for the quick turnaround!
Does this sensor from Ali Express work with edge on ST without the need of the Tuya hub?
Can someone confirm before I order.
Thanks.
Yes it connects directly to ST hub
Thank you. Have you found any issues at all with them? Randomly going offline etc? I see another post where someone doesn’t recommend them because it constantly goes offline.
Thanks.
From my experience, ST says the sensor is offline but it still works, and has been online several weeks.
Oh really. That’s weird.
So works as normal even though ST says offline.
Merry Christmas! @Mariano_Colmenarejo Could you please add my leak sensor to your driver?
  • application: 40
  • endpointId: 01
  • manufacturer: _TZ3000_kyb656no
  • model: TS0207
Thank you in advance!
Hi @altimeter
This device was added several time ago
Install Zigbee Moisture Sensor Mc in your hub and try add your device
