I have an Aeotec Hub, bought when they discontinued support for the V1 hub. I have a WD100+ switch, and when I double tap up or down, I’d like to turn another light on or off.
I think this used to work with Smart Lighting, but it doesn’t currently. What do I need to get this to work? There’s lot of advice in the forums, but it seems to use the old app, or otherwise out of date.
Tim links to the latest DTH in his last post - probably needs to be ported to a ‘driver’ if it hasn’t been already. And if you run into trouble others with the device are likely to congregate there.
