Door lock Kwikset home connect 620 edge driver?
I just installed a new Kwikset 620, (z-wave 700) I took a couple inclusions/exclusions before it got picked up correctly, but it is using a stock device type Z-Wave Lock instead of using the edge driver from Smartthings Drivers (Beta) Z-wave Lock. (Which is installed and in use for another lock)
is it compatible with smartthings? Is there a edge driver that should work with this lock.
I was able to use the edge driver z-wave lock for my kwikset smarcode 5, just by excluding it and readd it.
thanks for your advice.
