I installed the dlink 2132L camera and have it running but I don’t have all the configuration options as I would if I installed using the dlink site/app. I already have it running through smartthings but is there a way to use the dlink app to do the configuration and setup the record to sd card while keeping it connected to smartthings or will setting it up in the dlink app causes issues with the connection to smartthings?
You should be able to use both simultaneously, it is a LAN connected device so it should support multiple connections.
