Hey. I’m new to ST and I added a Xiaomi temp\humidity sensor manually. I was able to pair it but no information is displayed. It just shows 0% for temp. What I’m I doing wrong?
Please check this discussion from earlier this week… ![]()
I have tried using that DH you mentioned and have paired the xiaomi sensor but it still shows 0%. Does it take time to report the temp and humidity?
Temp sensors usually take a while until they report unless the temperature changes. So, either wait a bit or put it in the fridge for a minute
Did you get this working? Im considering buying 3-4 of them myself.
I have two that have been working without issues for a couple of months now.
Integrated directly with smartthings without any special bridge/hub between the sensor and ST?
I am in a similar situation, I bought the Original Xiaomi Temperature, not the Aqara one. So I am not sure which DTH to use.
Integrated directly. You can follow the links in my post above to the instructions on how to connect it to Smartthings and the DTH.
