Wondering if someone can help. I have a bunch of Xiaomi Aquara buttons, which have all dropped off the system, I decided to delete them from ST in order to add them again. I haven’t been able to add any, however, one of the deleted buttons shows in the Live Log when I press it. I can’t use the button, as there is no such device in the smartthings ‘Devices’ list.
Does anyone know how to remove this device so it is not connecting in live logging?
Many thanks.
K.
RBoy
2
Check your IDE, if it’s there then you should delete it from there. I’ve seen issues where the new app shows devices which don’t exist in the IDE also. You may want to report it to ST support also if you see the device in the IDE and not in the ST app. (I’m assuming you’ve checked that it’s not hidden)
If the device was previous being used in any SmartApps, it might be worth checking them to see if there is still any reference to it. It should have been deleted from them automatically but apparently some aren’t as keen to let go as they should be. However I think that issue makes itself known in other ways so it is a long shot.
I only have the one location, and the device is one of about 8 buttons that no longer work, so I’m not sure which one it is. They are a nightmare to pair, so probably won’t be able to.
