Thanks for the tip about Frient sensors. They seem to be exactly identical to Develco.
Iām still having a problem with humidity sensor. I was able to edit the code to identify the sensor but iām only getting temperature reading.
Code
import physicalgraph.zigbee.zcl.DataType
metadata {
definition(name: āSmartSense Temp/Humidity Sensorā, namespace: āsmartthingsā, author: āSmartThingsā, runLocally: true, minHubCoreVersion: ā000.017.0012ā, executeCommandsLocally: false, ocfDeviceType: āoic.d.thermostatā) {
capability āConfigurationā
capability āBatteryā
capability āRefreshā
capability āTemperature Measurementā
capability āRelative Humidity Measurementā
capability āHealth Checkā
capability āSensorā
fingerprint profileId: "0104", inClusters: "0001,0003,0020,0402,0B05,FC45", outClusters: "0019,0003", manufacturer: "CentraLite", model: "3310-S", deviceJoinName: "Multipurpose Sensor"
fingerprint profileId: "0104", inClusters: "0001,0003,0020,0402,0B05,FC45", outClusters: "0019,0003", manufacturer: "CentraLite", model: "3310-G", deviceJoinName: "Centralite Multipurpose Sensor" //Centralite Temp & Humidity Sensor
fingerprint profileId: "0104", inClusters: "0001,0003,0020,0402,0B05,FC45", outClusters: "0019,0003", manufacturer: "CentraLite", model: "3310", deviceJoinName: "Multipurpose Sensor"
fingerprint profileId: "0104", deviceId: "0302", inClusters: "0000,0001,0003,0402", manufacturer: "Heiman", model: "b467083cfc864f5e826459e5d8ea6079", deviceJoinName: "Orvibo Multipurpose Sensor" //Orvibo Temperature & Humidity Sensor
fingerprint profileId: "0104", deviceId: "0302", inClusters: "0000,0001,0003,0402", manufacturer: "HEIMAN", model: "888a434f3cfc47f29ec4a3a03e9fc442", deviceJoinName: "Orvibo Multipurpose Sensor" //Orvibo Temperature & Humidity Sensor
fingerprint profileId: "0104", inClusters: "0000, 0001, 0003, 0009, 0402", manufacturer: "HEIMAN", model: "HT-EM", deviceJoinName: "HEIMAN Multipurpose Sensor" //HEIMAN Temperature & Humidity Sensor
fingerprint profileId: "0104", inClusters: "0000, 0001, 0003, 0402, 0B05", manufacturer: "HEIMAN", model: "HT-EF-3.0", deviceJoinName: "HEIMAN Multipurpose Sensor" //HEIMAN Temperature & Humidity Sensor
fingerprint profileId: "0104", deviceId: "0302", inClusters: "0000,0001,0003,0020,0402,0405", outClusters: "0003,000A,0019", manufacturer: "frient A/S", model :"HMSZB-110", deviceJoinName: "frient Multipurpose Sensor" // frient Humidity Sensor
fingerprint profileId: "0104", deviceId: "0302", inClusters: "0000,0001,0003,0020,0402,0405", outClusters: "0003,000A,0019", manufacturer: "Develco Products A/S", model :"HMSZB-110", deviceJoinName: "Develco Humidity Sensor" // Develco Humidity Sensor
simulator {
status 'H 40': 'catchall: 0104 FC45 01 01 0140 00 D9B9 00 04 C2DF 0A 01 000021780F'
status 'H 45': 'catchall: 0104 FC45 01 01 0140 00 D9B9 00 04 C2DF 0A 01 0000218911'
status 'H 57': 'catchall: 0104 FC45 01 01 0140 00 4E55 00 04 C2DF 0A 01 0000211316'
status 'H 53': 'catchall: 0104 FC45 01 01 0140 00 20CD 00 04 C2DF 0A 01 0000219814'
status 'H 43': 'read attr - raw: BF7601FC450C00000021A410, dni: BF76, endpoint: 01, cluster: FC45, size: 0C, attrId: 0000, result: success, encoding: 21, value: 10a4'
preferences {
input "tempOffset", "number", title: "Temperature offset", description: "Select how many degrees to adjust the temperature.", range: "*..*", displayDuringSetup: false
input "humidityOffset", "number", title: "Humidity offset", description: "Enter a percentage to adjust the humidity.", range: "*..*", displayDuringSetup: false
tiles(scale: 2) {
multiAttributeTile(name: "temperature", type: "generic", width: 6, height: 4, canChangeIcon: true) {
tileAttribute("device.temperature", key: "PRIMARY_CONTROL") {
attributeState "temperature", label: '${currentValue}°',
backgroundColors: [
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
valueTile("humidity", "device.humidity", inactiveLabel: false, width: 2, height: 2) {
state "humidity", label: '${currentValue}% humidity', unit: ""
valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false, width: 2, height: 2) {
state "battery", label: '${currentValue}% battery'
standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", action: "refresh.refresh", icon: "st.secondary.refresh"
main "temperature", "humidity"
details(["temperature", "humidity", "battery", "refresh"])
log.debug ādescription: $descriptionā
// getEvent will handle temperature and humidity
Map map = zigbee.getEvent(description)
if (!map) {
Map descMap = zigbee.parseDescriptionAsMap(description)
if (descMap.clusterInt == 0x0001 && descMap.commandInt != 0x07 && descMap?.value) {
if (descMap.attrInt == 0x0021) {
map = getBatteryPercentageResult(Integer.parseInt(descMap.value,16))
} else {
map = getBatteryResult(Integer.parseInt(descMap.value, 16))
} else if (descMap?.clusterInt == zigbee.TEMPERATURE_MEASUREMENT_CLUSTER && descMap.commandInt == 0x07) {
if (descMap.data[0] == "00") {
log.debug "TEMP REPORTING CONFIG RESPONSE: $descMap"
sendEvent(name: "checkInterval", value: 60 * 12, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
} else {
log.warn "TEMP REPORTING CONFIG FAILED- error code: ${descMap.data[0]}"
} else if (map.name == "temperature") {
if (tempOffset) {
map.value = new BigDecimal((map.value as float) + (tempOffset as float)).setScale(1, BigDecimal.ROUND_HALF_UP)
map.descriptionText = temperatureScale == 'C' ? '{{ device.displayName }} was {{ value }}°C' : '{{ device.displayName }} was {{ value }}°F'
map.translatable = true
} else if (map.name == "humidity") {
if (humidityOffset) {
map.value = (int) map.value + (int) humidityOffset
log.debug "Parse returned $map"
return map ? createEvent(map) : [:]
def getBatteryPercentageResult(rawValue) {
log.debug āBattery Percentage rawValue = {rawValue} -> {rawValue / 2}%ā
def result = [:]
if (0 <= rawValue && rawValue <= 200) {
result.name = 'battery'
result.translatable = true
result.value = Math.round(rawValue / 2)
result.descriptionText = "${device.displayName} battery was ${result.value}%"
return result
private Map getBatteryResult(rawValue) {
log.debug āBatteryā
def linkText = getLinkText(device)
def result = [:]
def volts = rawValue / 10
if (!(rawValue == 0 || rawValue == 255)) {
def minVolts = 2.1
def maxVolts = 3.0
def pct = (volts - minVolts) / (maxVolts - minVolts)
def roundedPct = Math.round(pct * 100)
if (roundedPct <= 0)
roundedPct = 1
result.value = Math.min(100, roundedPct)
result.descriptionText = "${linkText} battery was ${result.value}%"
return result
- PING is used by Device-Watch in attempt to reach the Device
def ping() {
return zigbee.readAttribute(0x0001, 0x0020) // Read the Battery Level
def refresh() {
log.debug ārefresh temperature, humidity, and batteryā
def manufacturer = device.getDataValue("manufacturer")
if (manufacturer == "Heiman"|| manufacturer == "HEIMAN") {
return zigbee.readAttribute(zigbee.POWER_CONFIGURATION_CLUSTER, 0x0021, [destEndpoint: 0x01])+
zigbee.readAttribute(0x0402, 0x0000, [destEndpoint: 0x01])+
zigbee.readAttribute(0x0405, 0x0000, [destEndpoint: 0x02])
} else if (isFrientSensor()) {
return zigbee.readAttribute(zigbee.POWER_CONFIGURATION_CLUSTER, 0x0020)+
zigbee.readAttribute(zigbee.TEMPERATURE_MEASUREMENT_CLUSTER, 0x0000)+
zigbee.readAttribute(zigbee.RELATIVE_HUMIDITY_CLUSTER, 0x0000)
} else if (isDevelcoSensor()) {
} else {
return zigbee.readAttribute(0xFC45, 0x0000, ["mfgCode": 0x104E]) + // New firmware
zigbee.readAttribute(0xFC45, 0x0000, ["mfgCode": 0xC2DF]) + // Original firmware
zigbee.readAttribute(zigbee.TEMPERATURE_MEASUREMENT_CLUSTER, 0x0000) +
def configure() {
// Device-Watch allows 2 check-in misses from device + ping (plus 1 min lag time)
// enrolls with default periodic reporting until newer 5 min interval is confirmed
sendEvent(name: ācheckIntervalā, value: 2 * 60 * 60 + 1 * 60, displayed: false, data: [protocol: āzigbeeā, hubHardwareId: device.hub.hardwareID])
log.debug "Configuring Reporting and Bindings."
// temperature minReportTime 30 seconds, maxReportTime 5 min. Reporting interval if no activity
// battery minReport 30 seconds, maxReportTime 6 hrs by default
return refresh() +
zigbee.temperatureConfig(30, 300) +
zigbee.configureReporting(zigbee.POWER_CONFIGURATION_CLUSTER, 0x0021, DataType.UINT8, 30, 21600, 0x10) +
zigbee.configureReporting(0x0405, 0x0000, DataType.UINT16, 30, 3600, 100, [destEndpoint: 0x02])
return refresh() +
zigbee.configureReporting(zigbee.RELATIVE_HUMIDITY_CLUSTER, 0x0000, DataType.UINT16, 60, 600, 1*100) +
zigbee.configureReporting(zigbee.TEMPERATURE_MEASUREMENT_CLUSTER, 0x0000, DataType.INT16, 60, 600, 0xA) +
zigbee.configureReporting(zigbee.POWER_CONFIGURATION_CLUSTER, 0x0020, DataType.UINT8, 30, 21600, 0x1)
return refresh() +
} else {
return refresh() +
zigbee.configureReporting(0xFC45, 0x0000, DataType.UINT16, 30, 3600, 100, ["mfgCode": 0x104E]) + // New firmware
zigbee.configureReporting(0xFC45, 0x0000, DataType.UINT16, 30, 3600, 100, ["mfgCode": 0xC2DF]) + // Original firmware
zigbee.batteryConfig() +
private Boolean isFrientSensor() {
device.getDataValue(āmanufacturerā) == āfrient A/Sā
private Boolean isDevelcoSensor() {
device.getDataValue(āmanufacturerā) == āDevelco Products A/Sā
Humidity sensors Technical manual can be found here.
