Files in channel
RDG_Zigbee-button
- SONOFF SNZB-01 (WB01)
11-25-2021 - Driver added. Smartthings app 1.7.73.22 displays all actions in details view, but the only supported actions are Pressed, Pressed 2 times and held.
RDG_Zigbee-temp
- SONOFF SNZB-02.
11-06-2021 - Driver updated with ability to change temperature reporting interval (5-120 minutes) and temperature change amount (.1 to 5 degrees). Defaults set at 30 minutes and 1 degree.
Updated driver should show within 12 hours. Recommended to remove device and driver, then reinstall driver and rejoin device if you have any issues or don’t want to wait the 12 hours.
Noticed it can take some time for reported value changes to shop up in the history.
RDG_Zigbee-switch
- innr A19 Smart Bulb White
- innr A19 Smart Bulb Color
This is all new to me, but here is what I’ve noticed over the last 3 or 4 days of use. Looking through the events, reporting appears to work on .1 degree and 1% humidity changes. No idea on time interval as the room my sensor is in changes quite frequently. The sensor has not gone offline since installing this driver, but I understand that is probably because of the frequent temp changes.
Also have a driver to support the innr bulbs I use. Includes fingerprints for the Ecosmart-ZBT-A19-CCT-Bulb and innr SP 224 smart plug, but I have not tested either of those.
