I have written several custom DH in the past and all work fine in the classic app. The new app, on the other hand, totally messes them up. As an example, below are screenshots of my UPS unit. Currently, the classic app continues to display each attribute correctly. The new app on the other hand
Is there something I need to do to each of my custom DH to make them work properly in the new app?
This is the DH I use for the above device
* UPS Device*
* Author: C Dikland *
* Date: 2018-05-05
// for the UI
metadata {
// Automatically generated. Make future change here.
definition (name: "Cyberpower UPS Tile v1", namespace: "cdikland", author: "CK Dikland") {
capability "Battery"
attribute "comm_lost", "string"
attribute "model_name", "string"
attribute "power_supplied", "string"
attribute "voltage_condition", "string"
attribute "ups_load", "string"
attribute "battery_situation", "string"
attribute "battery_capacity", "string"
attribute "input_voltage", "string"
attribute "output_voltage", "string"
attribute "load_level", "string"
attribute "current_watt", "string"
attribute "remain_runtime", "string"
attribute "last_event_date", "string"
attribute "update_time", "string"
command "refresh"
preferences {
input "zipCode", "text", title: "Zip Code (optional)", required: false
tiles {
valueTile("comm_lost", "device.comm_lost") {
state "default", label:'comm_lost ${currentValue}',
backgroundColors:[
[value: 19, color: "#9F8ACD"],
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
valueTile("model_name", "device.model_name") {
state "default", label:'model_name ${currentValue}',
backgroundColors:[
valueTile("power_supplied", "device.power_supplied") {
state "default", label:'power_supplied ${currentValue}',
backgroundColors:[
valueTile("voltage_condition", "device.voltage_condition") {
state "default", label:'voltage_condition ${currentValue}',
backgroundColors:[
valueTile("ups_load", "device.ups_load") {
state "default", label:'ups_load ${currentValue}',
backgroundColors:[
valueTile("battery_capacity", "device.battery_capacity") {
state "default", label:'${currentValue}%',
backgroundColors:[
valueTile("battery_situation", "device.battery_situation") {
state "default", label:'${currentValue}',
backgroundColors:[
valueTile("input_voltage", "device.input_voltage") {
state "default", label:'Input ${currentValue}V',
backgroundColors:[
valueTile("output_voltage", "device.output_voltage") {
state "default", label:'Output ${currentValue}V',
backgroundColors:[
valueTile("load_level", "device.load_level") {
state "default", label:'Load ${currentValue}%',
backgroundColors:[
valueTile("current_watt", "device.current_watt") {
state "default", label:'Draw ${currentValue}W',
backgroundColors:[
valueTile("remain_runtime", "device.remain_runtime") {
state "default", label:'Remain Time ${currentValue}',
backgroundColors:[
valueTile("last_event_date", "device.last_event_date") {
state "default", label:'Last Event Date ${currentValue}',
backgroundColors:[
valueTile("update_time", "device.update_time") {
state "default", label:'Last Update ${currentValue}',
backgroundColors:[
main(["battery_capacity", "battery_situation","input_voltage", "output_voltage", "load_level", "current_watt" , "remain_runtime", "update_time","comm_lost","power_supplied","voltage_condition","ups_load"])
details(["battery_capacity" , "battery_situation","input_voltage", "output_voltage", "load_level", "current_watt", "remain_runtime", "update_time","comm_lost","power_supplied","voltage_condition","ups_load"])}
log.debug "Parsing '${description}'"
def generateEvent(Map results) {
results.each { name, value ->
sendEvent(name: name, value: value)
return null
def refresh() {
def configure() {
