Ok so I am looking into my curtain automation option. I am looking at the track and motor setups and would like to know what I require to satisfy the below requirements.
Alexa voice connectivity
Open/Close option
Stop motion at point
Select % close point
I have been looking at the somfy motors which may allow for direct connectivity, but not sure if it would work in the UK or satisfy the above requirements.
I also looked at fibaro shutters or dimmers but not sure what motor and DH requirements are necessary. I have been reading the motor may require 4 wires.
I am happy to look at any option but would like to know what is required for the complete setup including any necessary DH’s. Really appreciate anyone’s help .thanks
I’m also interested in this, but am as in the dark as you are!
I am toying with the idea of picking up a Dooya curtain motor (seem to be the best low cost option on the market - very quiet and reliable) and using a Z wave controller for open/close.
The main issue is cost of importing large curtain rails from the far east.
A quick Google suggests that India operates a different Z wave frequency to the UK/EU unfortunately… Though the modular design of the Z wave ‘dongle’ in that video may mean an EU frequency model is available.
They said they are planning on selling to the UK with connectivity to smartthings. Here is a quote from an email chain I had with them
"Yes, we are currently working on finalizing the distributor for the UK region. Meanwhile, we can get your order processed if you are interested in ordering directly with us?
Please let us know and we will forward the request to the proper department.
I had a good experience buying from AliExpress. For example a 150cm Dooya curtain rack costs about 100 US, plus 20 for shipping, They take 7 days to arrive in Europe, they’re a 4 wire motor, added a three-way momentary switch to each one, a Fibaro Shutter 2 and a device handler by @julbmann, the whole process couldn’t of been any easier. And obviously they work with Google home or Alexa.
By “manual relay override” you mean a physical switch? Yes i installed a three-way physical switch next to the curtains, but it’s mostly done via automation. the motor can be fitted either left or right, with a white cap to place on the motor connection side not used. it’s very silent, and in no way would the quality make one assume they were from the Far East. The cord from the motor is about 100 cm long, and you have to buy your own switch, that’s it. The chap from the shop is very helpful, writes in English, he’s called Scott Liu from “Friend Industry Holding”, here’s the link.
When I refer to manual relay I mean if I manually pull the curtain will it feedback to the motor to either open or authorized the curtain. See attached video using the hogar controller.
I see, mine are kind of hard to reach, but I just physically changed their position by hand and it didn’t report back to the Fibaro.
Luckily the dth has a “Calibrate” tile on it. I would never open them by hand personally, there’s a switch, and I have a webCoRE piston that opens them randomly between 80-100% to mimic someone doing it by hand.
I have recently been looking at a curtain system for the UK but with slightly different criteria but since this thread has sprung back in to life I will add my current findings.
Aqara do one that uses Zigbee and they also do their own hub. This is UK compatible and available but they are in the process of releasing a new M2 Hub so I would hold off and wait for that. They can be connected to Smartthings and they can also be connected to HomeKit however I am getting the impression that to use HomeKit puts it in a mode that precludes other connectivity like Smartthings at the same time. This is unusual and would seem unnecessary as the Philips Hue hub for example has no problems doing HomeKit and other connectivity at the same time.
I personally find the whole Aqara product line a confusing mess for this and other reasons and as long as the next option evolves that way I expect I will not be using Aqara myself.
Slide is a newish startup. They are European and make a smart curtain system and I believe already support Alexa and are in the process of adding Google Home. I am unsure about Smartthings.
They are intending to add HomeKit support. This is the system I am currently considering myself.
Somfy are a French company but also sell in the UK. They do have a smart curtain solution which uses their own proprietary 433MHz RTS system but there are some integrations listed in these forums to link it to Smartthings. They did at one point promise to add HomeKit support but now appear to have pulled out of this. I am therefore excluding them from my own considerations.
There are several systems listed on Amazon but at least as far as HomeKit support cheat if not out and out lie. The way they do HomeKit and possibly other integrations is to have a separate smart plug e.g. EveHome and when that plug cycles the power this is detected by their product and causes the motor to activate. If closed it opens, if open it closes. This of course means you cannot open to say 50%.
There is an ultra high end and hence hugely expensive Lutron solution.
Be aware, a lot of discussions even if the word curtain is included will misleadingly actually talk only about blind only solutions. Soma for example only do blind solutions and no curtain solutions. Similarly so far Ikea only do blinds.
Also be aware that the US calls curtains ‘drapes’.
