I have five CT100 thermostats around my house, but one in particular keeps losing connectivity to the hub. It claims to have a connection on the device, but is neither reporting its current values nor accepting the ones I’m setting.
Does anybody have suggestions for how to debug it?
Here are a few things I’ve tried/checked so far:
- On graph.api.smartthings.com, it is listed as inactive.
- I’ve tried it with the default CT100 device type, as well as RBoy’s custom handler (which works great for all the others)
- It’s in an area with plenty of other powered Z-Wave devices, so signal shouldn’t be an issue. I’ve repaired the network a number of times.
- As a thermostat it seems to function fine, it calls for heat properly and so forth.
Any debugging pointers would be appreciated! Given that 4 of 5 working, I also have to consider the chance I’ve just got a bad device…
