I have added the webcore smart app to my set up, following all the steps in https://wiki.webcore.co/webCoRE#Installing_webCoRE. when trying to create my first piston - I enter the name, click create and then the spinner stays forever. If I try to create another piston, I get the same behavior.
I removed the app, redefined the repo and retried - same results.
Open the IDE in another browser and go to live logging. Try creating a piston again and look for the logs for webcore. Should see an error supplied somewhere
My account has a location set up (home) and I have a single hub. should i send you the app settings? The webcore apps are assigned to that home location
Please reset your location timezone - I believe you can do that in the app by moving your pin to a different location and then back where you need it to be - or maybe somewhere in the Locations settings in the IDE - maybe others know better - but you are missing the location information and along with it, the timezone. I will make the SmartApp test for location and timezone during install once I find instructions on how to do it - so if you find a way, please detail it here. Please
