I changed mine in the smart app, my location was reading wrong.
Open Smartthings App,
Click 3Bars top left of app
Click GEAR Icon on slide out window
On the on the Google Map Make sure it shows your location (click Save if your location is correct)
If not press on the map to open the location screen
drag the blue dot to your location and save.
Try Creating a Piston, Enjoy!
I could’t find a way to update my location with IDE.
Thank you, we’ll put that in the wiki and also have the app warn about the location not being valid. @c1arkbar can you please update the wiki, or have someone do it? I’ll take care of the app
I have done the same thing. In the android app I played with the location (moved the map), but re-saved to the original one. that did the job. there was no other place to change the location
I have added a check in the installation process that guides the user towards setting up his location - you can no longer install webCoRE until the timezone/location is properly setup. I also made sure to throw an error in the piston if timezone is not present. I will also add a warning on the dashboard in a future release. Thank you for figuring out the steps to fix this.
