Control4 LSZ-3W1-W Dimmer
still top result when you search “control4”
I don’t offer support for it but it still works for my dimmers.
Will only do basic pairing and control dimming.
The switches and dimmers must be running zigbee pro, not embernet.
The 3W1 are 3 button keypads, meaning they don’t control the load, and my driver probably can support it, but would need to be modified to see the different button presses. I don’t have 3 button keypads.
Best thing to do is, see if it pairs up with ST, watch the logs in the IDE.
Switch to my device type which should have enough debugging to look for the control4 messages.
Press each button on the keypad and see if the logs show anything.
Upload logs, I might be able to make some easy modifications to get all the buttons to work.
