I have smart devices randomly spread out throughout the house and I’m slowly getting them all added to my hub, even those which aren’t natively supported. This forum has been a great resource. I have Alexa also and I’ve learned how to use that as a middleman along with creating virtual switches to get those devices to show in smartthings.
I have several WiFi RGBW bulbs. They are Sylvania bulbs if that helps. I’m starting just testing my options on one and then I will follow the same steps for the others. I have a simulated switch and contact sensor set up and routines in Alexa to turn the switch on or off if the simulated switch is pressed. That works fine.
My question is can I also control the color changing features and dimming the bulbs using the smartthings app? Or would this require creating routines for every single different scenario (if simulated switch is set to red, set bulb to red, etc)? I’m obviously not going to do that haha. Just wondering if I could set the simulated device differently or if there’s an existing smartapp to accomplish this.
Thanks !
