I can’t seem to find a recent list of connected lighting products - does that exist anywhere in the community here (as opposed to the official ST site, which for lighting has a pretty short list that’s basically Sylvania + Philips).
I’ve had problems with controlling my Sylvania Flex - the behavior is far from optimal. Unfortunately the US subsidiary basically threw up their hands and said, “email the guys in Germany,” which I did a few times and haven’t heard a peep in about a week, so I’m losing hope.
It would be neat to see a Google Sheet (or similar) with supported lighting, maybe with features as yes/no columns: on/off only, dimmable, whitecolor control, full RGB, etc.
Doublecheck everything you see at that site before actually buying anything. It has some weird algorithm, I’m not sure how it decides what compatible or not.
For example, it says that the smartthings hub is compatible with the wink hub and with the Lutron smartbridge.
All 3 have IFTTT channels, but that’s definitely not the same thing as full compatibility.
There will be some indirect compatibility with anything that has an IFTTT channel, but there may be some additional lag and there may be a very limited features that that is exposed to the channel.
So it’s OK as a starting place, but you need to dig deep from there.
Luckily, for most of those items, it does show the integration is IFTTT under the “How To” column.
Although it also says that’s how SmartThings communicates with Logitech Harmony. While you obviously could communicate through IFTTT alone, there is a cloud connection for that product.
For smaller individual components like sensors, switches, and bulbs, the list is much more accurate (although never guaranteed to be 100% correct).
