Connect hive/ikea bulbs directly to ST hub v3
Hey y’all,
I wondered if I would be able to directly connect Hive bulbs to a SmartThings v3 hub. At the moment they are paired to my Amazon Echo with Zigbee built in but it’s been flaky and unreliable.
I also have a TRADFRI Ikea bulb which I would like to pair as well.
I do not have a Hive hub, but I do have a TRADFRI hub but I’m more than happy to move to ST.
Is it possible?
Thanks guys
The Tradfri bulbs definitely work, lots of people use those with a SmartThings hub. :sunglasses:
I’m not sure about the Hive bulbs, but they would probably work if they worked with echo. It’s the same profile.
Ok! Thanks for the help. I’ve seen an Amazon review that said they managed to pair a hive bulb via zigbee to the hub so I should be fine.
Thanks for helping out :slight_smile:
