How are they (LIFX) for direct Alexa commands?
I just played with my AEON and could not change color with Alexa.
Edit - all I see is WI-FI, am I missing Zigbee or Z-wave? Link?
I can say to mine Alexa, make the porch light red or Alexa make the outside lights blue. That is through integration with LIFX and Alexa. It does not involve Smartthings. Although all of my LIFX bulbs are integrated with Smartthings as well.
I don’t change the colors on mine that much, I do use the color coordinator app with a few virtual switches, that can be triggered with voice commands.
Aeotec doesn’t connect directly to your Amazon account, you have to go through SmartThings. So most likely you would have to set up a SmartThings scene for the color changes you want, and then use Alexa to activate those scenes.
Have you tried creating a scene with the different colors? Scenes have been added to the platform since that DTH was written. And you can now activate them with the official smart lighting feature. So you should be able to activate the scenes with Echo.
I use a couple of Osram/Sylvania BR30 bulbs in a flood light fixture in my back yard. They’re under the eve but otherwise full exposed. This is in sunny AZ, though.
They’re pointed down, so if they did get a little water in them through the cover, it wouldn’t run into the electronics.
I’ve used sengled bulbs outdoors for a while now, both color and soft white. Held up surprisingly well in Chicago winters, one of my white bulbs has the tiniest flicker but all the others are going strong after a year.
Edit for clarification: one under the porch overhang and two in bottomless fixtures. Strangely it was the one on the porch that developed the flicker. The white bulbs were outside for about a year and a half, just switched to color about 6 months ago.
