No, you need to make the corresponding tests on your side first (this includes receiving the streaming in the device).
When you make a Publish Request, the certification team tests your device as well and, if it doesn’t pass all of them, it will be rejected until you fix the issue (in this case, showing the streaming video). -
Ok, let’s discuss this further.
As I understand:
- You have a main device (the IR) that will be able to control several devices.
- You want to add those devices in the same Schema Connector so, when the IR receives a command, you’re able to send it to the other devices
Which commands would you send from the IR to the other devices? Please provide a list of what the IR would be able to control from the others. - But, those devices wouldn’t show any state in their details, so, what would you show?
Note: About controlling a TV, please take a look at this post. Currently, the TV capabilities are not working correctly, you would have to use custom ones but they are not accepted in the certification yet.
Remember you can also share the information by sending an email to build@smartthings.com to protect the privacy of your integration.
