I recently purchased an old alarm system on a flea market with the idea of using it’s wireless sensors with smartthings.
They are rebranded by the alarm company, but originally from climax.
A power outlet (pss-23)
A motion sensor (ir-9)
A door sensor (dc-15)
And a few other things, like a keypad.
All with a sticker saying 868 MHz on the back.
The smartthings hub does not find any of the items when searching.
Has anyone attempted anything similar?
Shouldn’t the hub see it as a “thing” no matter what?
(I have both the UK and the US hub, no luck with either. 868 MHz should be European z-wave)
Any information is appreciated.
Are you sure it’s a z-wave device? 868MHz is the European z-wave frequency, but I’m sure it’s possible this company could use a proprietary protocol on the same frequency.
Check https://products.z-wavealliance.org and if it’s a certified z-wave device it will be listed there.
Also if it is and-wave device, you should make sure it’s been excluded from any previous z-wave controller, and when the ST hub is in pairing mode, you’ll probably have to push a button on the device. Check the device’s manual; it should be pretty clear whether it’s a z-wave device, and if it is it’ll have instructions for both the exclusion and inclusion procedure.
SmartThings provides instructions on how to exclude a z-wave device that’s not already paired to your ST hub. There are two different versions of the mobile app now.
https://support.smartthings.com/hc/en-us/articles/200878314-How-to-exclude-Z-Wave-devices
Oh hi Mark.
Thank you for your reply. I think you are right about it being just on the same frequency, but not a z-wave device. That makes sense since they have a version named ir-9zw also, which must be the z-wave version.
So unfortunately I won’t be able to connect with smartthings.
Luckily it was cheap.
Thanks for the quick response.
Did anyone else open this post and expect to find something completely different. I know we’re mostly male and mostly nerds (in a good way) but a “Climax Alarm”. Come on…that’s just begging for a dirty joke isn’t it?
Yes, for a moment, but only briefly.
Previously I was having problems with my wife’s presence detection on her phone, and deleted her via the IDE. Getting her back in made me run into a brick wall, so I asked for help with the subject line “I deleted my wife from SmartThings and now I can’t get her back” which is the perfect description of my issues. Several members here read this differently, and I even got one reply saying something similar to “I wish I could delete my wife”
Being geeks we tend to have a different type of mind. I do think an alarm is unnecessary if we think like Ryan780
