After i am Forced to use the new smartthings app because the old version doesnt work for me anymore (cant add routines anymore) i am having troubles with the following :
When i start the app lots of devices give me the Checking Status , when i close and open the app its all OK again.
Also when for example i want to use the Timer on a smart power outlet its not possible to turn on, i am unable to Check the box next to it so you can see the timer is active. When using the Turn OFF at xx-xx function it will work.
My other sensors and automations work just fine.
what i already have done is reset my HubV2 and reinstalled the App on the phone cleared all the data and cache but nothing is fixing my problems.
I see this. Sometimes, it takes anywhere from 5 (if I am lucky) to 30 seconds or longer for the status to update for devices. Many times, I close the app and open it again and they load quicker. There were a few updates of the app in late summer/early fall where everything loaded quickly. But since the November release, it has gotten much worse. This is only my opinion and I am sure others may have different experiences.
Every now and again, you may need to select it twice for it to stick or try choosing a custom time and then the timer shows as enabled.
Be patient, I am sure ST will resolve the issues in time. The app is constantly being updated.
Be sure to open a ticket with ST support and report any issues you encounter.
