Embedded in the lid of my âdelivery boxâ, 2m away from my SmartThings hub, and probably on average opened twice a dayâŠ
I installed another one in the door of my bike shed 6 months ago. Hope it will last longerâŠ
In particular, is there metal on either side of it?
One way to run down a sensor battery is to put it in a position where it has difficulty communicating so that messages have to be resent multiple times.
Nope, just chiseled a 4mm deep groove for the strip, and 2mm in the other side for the magnet. Brave wood box otherwise, then solid wood front door, and the hub in a wood cupboard next to the doorâŠ
Ah, I know that feel, used to live in South London. You guys had a LOT of snow last year, might have been enough to end it much earlier than expected. Not sure how much snow you are expecting this year!
Yeah, this pic from CES 2015 threw some cold water on me. Chamberlain = MyQ (still not officially supported), Somfy (still not officially supported), August (just added a couple months ago, and only the Pro model with z-wave).
I bet a virtual $20 that that âworks with nestâ only applies to the new platform which wonât run custom code. Because thatâs been nestâs biggest concern in the past.
Have you tried getting in touch with Sensativeâs support? Sometimes a sensor will report 0% or 1% battery if there is a communication or configuration issue. So itâs worth checking with them if they can offer some direct troubleshooting. Theyâve also been very flexible with the warranty coverage, at least for all of our US customers so far.
Not sure it helps but I installed a dozen of these 18 months ago and most still report 100% in SmartThings, with two reporting 75%. Only one, a door, is opened multiple times per day though.
The Zigbee Allianceâs big news about an industry liaison turned out to be the long-expected release of the Dot Dot 1.0 specification for dot dot over thread. And the liaison is the thread group.
Which, OK, in the long run might mean something but itâs not a typical CES type announcement. Just sayinââŠ
And besides, we all remember how well Zwave did with z/ip, right?
