Cannot pair Yale YRD210 deadbolt lock
You’re running into the stale cache DTH issue. When a DTH is unused for a long time ST makes it stale and there a bug in the platform where it does not refresh the cache due to which it ultimate timeouts out when trying to pair the device.
The solution is just to republish the DTH which refreshes the cache and everything works fine (you don’t need to remove the custom DTH if you’re still using it, if not then it’s a good practice to remove it). See this topic for details
