Cannot get light switch to show up
Switch used to work. Still works in terms of turning light on and off. Cannot get it to be seen by the hub. Ideas? It no longer shows up when I log into the dev site.
What make and model switch?
It’s a GE Z-Wave paddle switch
if it’s dropped off your system, you’ll have to run s device exclusion first to reset it and then re-add it. Here’s how to do that if you’re using the Classic app
