GE Zwave switch somehow dropped off my system when I was deleting a different device. Now the switch is not in my Smartthings device list–and when I try to add it, it does not show up.
Any idea how I find this ghost switch?/
Just do the Z-Wave exclusion sequence, its pretty simple, you put the hub in exclusion mode and press the top portion of the button. For GE you can also do a factory reset by some combo of presssing button ten time and playing with the airgap tag. You should be able to google that and there are videos for resetting GE zwave switches on youtube. Or you can call ST support, they are really good and will walk you through it
Worked like a charm! Forgot to thank you!
