Cannot create simulated switch
You can also install the SmartThings SmartApp that allows you to create virtual devices without the need for logging into the IDE.
It allows you to create a Virtual Switch and Virtual Dimmer Switch
Goto Marketplace / + More and scroll to bottom:
It will create each device as Virtual Switch 1…2. Then go into Things and rename it.
