Can you rename a virtual switch?
I have a virtual switch called simply virtual switch… I’m using it now for Alexa to mute and unmute my phone via IFTTT.
I wanted to rename it to Phone or something like that.
Can I do that or do I need to remove from smartapps first?
I know I’d have to rediscover with the Echo after.
Thanks in advance…
Renaming a virtual device or any other device in that matter, should not be an issue. I’ve done it many times.
Are there tasks to do after I rename it? or are the smartapps using the device ID internally and not the name?
Do I change both the name and the label?
Thanks :slight_smile:
I usually do it from the IDE and change the name and label. I don’t believe there are any tasks. Try one and see if it still works :slight_smile: You can always change it back.
Many thanks
It is easiest to do in the phone app. If you change a device name in Smartthings it is automatically changed for all apps etc within Smartthings. I think IFTTT also updates automatically. For Alexa I think you have to tell “Alexa discover new devices” to update. In case you use Homebridge you will have to restart it to load the new name.
Yes. Almost everything in SmartThings is accessed by Object ID (except Modes and Routines which are referenced by Name).
There is a tiny chance some SmartApps may use Device Name in places, but there is no reason for them to do this.
It is perfectly safe to rename Devices.
