Can the Smartthings Hub(v3) connected wirelessly be used as an access point?
Can the Smartthings Hub(v3) connected wirelessly be used as an access point? My hub is connected via WIFI, leaving the LAN port open. Could I use that port on the hub to connect a non-wifi device, in effect using the Hub as an access port?
Thank you.
What you describe is a WiFi bridge. No. it cannot do this.
Thank you for the information
Randy’s IPhone :palm_tree:
