Can’t Complete Aqara M2 Binding
I’m having trouble completing my Aqara M2 to SmartThings binding. I had it set up once and things were working swimmingly until the M2 had a firmware update. My Aqara went offline in the SmartThings app and upon checking the Aqara native app, it appeared to be online. Thus, I decided to remove the Aqara hub from SmartThings to set it up over again. I’ve gone through multiple power cycles, I did a reset on the Aqara hub and still having issues. It takes a couple of tries to get it added to my iCloud (through SmartThings), then proceeds to connect to the Aqara devices. Where it is failing now is the registration part to my Samsung account. Any idea on what I should do?
I land on the “Something went wrong” page with error code 39-517
I’m having the exact same issue…
I had it connected to SmartThings… then one day it was offline… I tried everything to get it back online…
Deleted it, factory reset the Aqara M2 Hub… and still get the error…
I read something about a Aqara Edge Driver for SmartThings… but I cant find one… Maybe that will fix it…
Those are only for people trying to add individual Aqara Zigbee end devices to a SmartThings hub, they don’t apply to adding the aqara hub as a matter bridge. So unfortunately, there’s no solution in that direction.
Typically this issue occurs when one or the other hub needs a firmware update and then it turns out that you need to reboot both of them in order to get them back in sync. :man_shrugging:t2:
Not sure if your M2 is hardwired or WiFi, but I ended up resolving my issues by hardwiring my M2.
I tried rebooting both… still a No-Go…
I have it in wifi right now… imma try and hardwire it… See if that works
It’s on wifi right now… imma try and hardwire it and see how that goes… thanks for the advice
Bro, does it works with hardwire it?
