Can I use Ecobee3 to control multiple disconnected zones
The new unit I am moving into has four individual thermostats controlling an electric radiator each. I am not keen on purchasing three new ecobees for this new setup.
I am wondering if anyone has ideas on some less expensive thermostats that I could somehow control based on ecobee settings and motion sensors.
-If ecobee is on, and a room is sensed as occupied, turn on thermostat.
  • If ecobee is off, turn off all generic thermostats
  • Maybe some adjustments based on ecobee home/away modes. I haven’t thought this through yet.
IDeas?
Yes, there is already an app for that. And it’s been used by many of my contributors.
http://thingsthataresmart.wiki/index.php?title=EcobeeSetZoneWithSchedule
The smartapp can do even more features based on the concept of zones:
  • Control of smart vents to create physical zones
  • Alternative cooling
  • Avg temp calculations based on any ST temp/motion sensors to make adjustment to your ecobee’s setpoints
  • More heat/cool thresholds based on an outdoor temp sensor.
Regards.
Thank you very much. Do you recommend a particular z-wave thermostat?
I’m not an expert in Z-wave thermostats as I mainly use ecobee at my home.
Look up for feedback in the ST community forum on the CT-100 and GoControl thermostats.
You can ask @RBoy for any good z-wave thermostats. He’s created good DTH for z-wave thermostats as well!
P.S. EcobeeSetZoneWithSchedule requires MyEcobee device as a prerequisites as it takes advantage of the advanced & comprehensive integration I’ve built with SmartThings. For more details, refer to
Depending on your electric radiator, you may also want to look into the Stelpro. I have it at home to control electric baseboards in my basement and it works very well.
The CT-101 and CT-100 are xcellent thermostats. The stock device handler works well for basic programming if you want some advanced features you can check out the Enhanced Z Wave thermostat device handler.
There is a new z wave plus version of the CT thermostat that’s out that you can purchase from ZooZ @TheSmartestHouse
Thanks for tagging us @RBoy
Here is the link to the new CT100 Plus thermostat:
Just wanted to thank you all for the input. I have a few projects before I get to this, but I have some ideas now.
Hi @brendonwbrown,
I’ve recently added more features to ecobeeSetZoneWithSchedule as posted under my thread:
The smartapp has become even smarter!
To download the code, go to
www.ecomatiqhomes.com/store
Regards.
