I see log calls in different code bases, but I am not seeing anything that allows me access to the logs. I have gone to live logging and that doesn’t appear to dumping any logs that are from custom apps. Only logs of devices
SmartApp’s log.* calls should be found there.
The only exception I know to this is when a child device calls a parent SmartApp, the SmartApp’s logs do not generate as expected, only the device’s. Unless this has been resolved.
Hmm, that is strange, I was specifically looking at the Smart Alarm app from @geko and I was playing with toggling the REST commands on\off, which was supposed to log the information.
Try looking under all, on the newest version of the Android app I noticed apps will name them “Tap to set” initially.
Also are you seeing any logs for any apps? If not try a different browser.
What do you mean, looking under All? On the Live Logging page, there is only one button for me and it is All and highlight blue.
I will keep an eye out on other apps. Is there a historic log? I see these people post the aftermath of a app failure and I am not sure where i am supposed to go for that.
I do not know how many devices you have connected but you should be seeing logging coming from other devices/apps. “All” will be highlighted first, then each App/Device that outputs logs will be listed to the right. In the “Logs” panel there will be an hashed id, ie “d89fsf7sfd-c7384-sa8d7-sad7d-lkj3457sdf8” if you click that link it should bring you to that App/Device’s individual logs.
There is no way to see historical logs unless you have the “Live Logging” open.
If you are not seeing any logs at all, do this.
- Install the latest version of Chrome
- Open an “Incognito” window (Ctrl+Shift+N)
- Go to the Web-IDE, click on “My Hubs” then click on “Live Logging”
You should see some logging. If you don’t make sure there aren’t any plugins/extensions interfering, you can temporarily disable them if needed.
Here is what my logging looks like after a few minutes, I have removed the IDs and logging that included sensitive data.
