BBoy486
September 30, 2017, 4:52pm
1
Now that Google Assistant is in Nvidia Shield TV can I use my Alexa to pass commands to GA.
Reason - right now the only way to envoke the shield is to use the Nvidia controller or remote. I don’t use those as I use a Harmony remote.
So maybe with Echosistent or Ask Alexa Alexa can be used to talk to the shield?
The easiest way is to set your controller nearby and use it like you would use google home. Works well. Other than that Alexa and Google Assistant don’t play nice with each other, yet
BBoy486
September 30, 2017, 5:04pm
3
But you have to press the button to envoke the mic
nope, not on the controller, you need to manually enable that feature. I have two controllers connected to mine and they hear pretty well.
BBoy486
September 30, 2017, 7:34pm
5
Where do you enable that?
Jbeck21
September 30, 2017, 8:53pm
6
The 2017 model controller does not need the button pressed to activate.
It asked me the first time I used the assistant. Look for assistant set up.
BBoy486
September 30, 2017, 11:36pm
8
I was using the old controller. The 2917 one worked but my phone is responding not the sheild
