Bosch Motion Sensor
(David Lam) #1
Which device handler do i use for local processing? I tried smart sense and it worked but it doesnt show temp and battery.
It will depend on the exact model that you have. See the following thread:
(David Lam) #3
I have the MCT-340 E which a lot of people purchased, I did not find anything in that thread that was helpful.
#4
I’m not aware of a Bosch MCT 340 E. There’s a Visonic Open//close sensor with that model number, is that what you have?
If so, see the following:
https://www.mydigitaldiscount.com/connecting-your-visonic-mct-340-e-window-door-sensor-to-smartthings.html
(David Lam) #5
I got it paired and working but I need it to run locally now, that is the problem. I got it running locally when i set it to smartsense motion detector but there is no temperature reading and also the motion is more grayed out than usual.
