Bosch ISW-ZDL1-WP11G Tritech Motion Detectors [work with SmartThings]
I’d like to share another success story of repurposing some equipment with SmartThings. I take no credit for the solutions, I just thought it would be helpful for someone else to have everything in one spot.
I managed to connect two Bosch ISW-ZDL1-WP11G Tritech Motion Detectors to SmartThings. I haven’t had much time to tweak their sensitivity or create any automation profiles for them yet but here is goes.
I found a Device Handler and instructions for syncing the device at this website:
https://www.mydigitaldiscount.com/connecting-your-bosch-isw-zpr1-wp13-wireless-pir-motion-sensor-to-Smartthings.html
The raw code for the device handler (please follow instructions in the above link to add the device handler to smartthings):
 *  Copyright 2017 Tomas Axerot
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not
 *  use this file except in compliance with the License. You may obtain a copy
 *  of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software
 *  distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
 *  WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the
 *  License for the specific language governing permissions and limitations
 *  under the License.
import physicalgraph.zigbee.clusters.iaszone.ZoneStatus
metadata {
	definition(name: "Bosch Motion Detector", namespace: "tomasaxerot", author: "Tomas Axerot") {
		capability "Motion Sensor"
		capability "Configuration"
		capability "Battery"
		capability "Temperature Measurement"
		capability "Refresh"
		capability "Health Check"
		capability "Sensor"
		command "enrollResponse"
		fingerprint inClusters: "0000,0001,0003,0402,0500,0020,0B05", outClusters: "0019", manufacturer: "Bosch", model: "ISW-ZDL1-WP11G", deviceJoinName: "Bosch TriTech Motion Detector"
    fingerprint inClusters: "0000,0001,0003,0402,0500,0020,0B05", outClusters: "0019", manufacturer: "Bosch", model: "ISW-ZPR1-WP13", deviceJoinName: "Bosch PIR Motion Detector"
	simulator {
		status "active": "zone report :: type: 19 value: 0031"
		status "inactive": "zone report :: type: 19 value: 0030"
	preferences {
		section {
			image(name: 'educationalcontent', multiple: true, images: [
					"http://cdn.device-gse.smartthings.com/Motion/Motion1.jpg",
					"http://cdn.device-gse.smartthings.com/Motion/Motion2.jpg",
					"http://cdn.device-gse.smartthings.com/Motion/Motion3.jpg"
		section {
			input title: "Temperature Offset", description: "This feature allows you to correct any temperature variations by selecting an offset. Ex: If your sensor consistently reports a temp that's 5 degrees too warm, you'd enter '-5'. If 3 degrees too cold, enter '+3'.", displayDuringSetup: false, type: "paragraph", element: "paragraph"
			input "tempOffset", "number", title: "Degrees", description: "Adjust temperature by this many degrees", range: "*..*", displayDuringSetup: false
	tiles(scale: 2) {
		multiAttributeTile(name: "motion", type: "generic", width: 6, height: 4) {
			tileAttribute("device.motion", key: "PRIMARY_CONTROL") {
				attributeState "active", label: 'motion', icon: "st.motion.motion.active", backgroundColor: "#00A0DC"
				attributeState "inactive", label: 'no motion', icon: "st.motion.motion.inactive", backgroundColor: "#cccccc"
		valueTile("temperature", "device.temperature", width: 2, height: 2) {
			state("temperature", label: '${currentValue}°', unit: "F",
					backgroundColors: [
							[value: 31, color: "#153591"],
							[value: 44, color: "#1e9cbb"],
							[value: 59, color: "#90d2a7"],
							[value: 74, color: "#44b621"],
							[value: 84, color: "#f1d801"],
							[value: 95, color: "#d04e00"],
							[value: 96, color: "#bc2323"]
		valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false, width: 2, height: 2) {
			state "battery", label: '${currentValue}% battery', unit: ""
		standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
			state "default", action: "refresh.refresh", icon: "st.secondary.refresh"
		main(["motion", "temperature"])
		details(["motion", "temperature", "battery", "refresh"])
	log.debug "description: $description"
	Map map = zigbee.getEvent(description)
	if (!map) {
		if (description?.startsWith('zone status')) {
			map = parseIasMessage(description)
		} else {
			Map descMap = zigbee.parseDescriptionAsMap(description)
			if (descMap?.clusterInt == 0x0001 && descMap.attrInt == 0x0020 && descMap.commandInt != 0x07 && descMap?.value) {
				map = getBatteryResult(Integer.parseInt(descMap.value, 16))
			} else if (descMap?.clusterInt == zigbee.TEMPERATURE_MEASUREMENT_CLUSTER && descMap.commandInt == 0x07) {
				if (descMap.data[0] == "00") {
					log.debug "TEMP REPORTING CONFIG RESPONSE: $descMap"
					sendEvent(name: "checkInterval", value: 60 * 12, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
				} else {
					log.warn "TEMP REPORTING CONFIG FAILED- error code: ${descMap.data[0]}"
			} else if (descMap.clusterInt == 0x0406 && descMap.attrInt == 0x0000) {
				def value = descMap.value.endsWith("01") ? "active" : "inactive"
				log.debug "Doing a read attr motion event"
				map = getMotionResult(value)
	} else if (map.name == "temperature") {
		if (tempOffset) {
			map.value = (int) map.value + (int) tempOffset
		map.descriptionText = temperatureScale == 'C' ? '{{ device.displayName }} was {{ value }}°C' : '{{ device.displayName }} was {{ value }}°F'
		map.translatable = true
	log.debug "Parse returned $map"
	def result = map ? createEvent(map) : [:]
	if (description?.startsWith('enroll request')) {
		List cmds = zigbee.enrollResponse()
		log.debug "enroll response: ${cmds}"
		result = cmds?.collect { new physicalgraph.device.HubAction(it) }
	return result
private Map parseIasMessage(String description) {
	ZoneStatus zs = zigbee.parseZoneStatus(description)
	// Some sensor models that use this DTH use alarm1 and some use alarm2 to signify motion
	return (zs.isAlarm1Set() || zs.isAlarm2Set()) ? getMotionResult('active') : getMotionResult('inactive')
private Map getBatteryResult(rawValue) {
	log.debug "Battery rawValue = ${rawValue}"
	def linkText = getLinkText(device)
	def result = [:]
	//ISW-ZPR1-WP13 uses 4 batteries, 2 are used in measurement
//ISW-ZDL1-WP11G uses 6 batteries, 4 are used in measurement
	if (!(rawValue == 0 || rawValue == 255)) {
		result.name = 'battery'
		result.translatable = true
		result.descriptionText = "{{ device.displayName }} battery was {{ value }}%"
		def model = device.getDataValue("model")
    def volts = rawValue // For the batteryMap to work the key needs to be an int
		def batteryMap = []
    def minVolts = 0
		def maxVolts = 0
    if (model == "ISW-ZDL1-WP11G") {
    	batteryMap = [60: 100, 59: 100, 58: 100, 57: 100, 56: 100, 55: 100,
    				  54: 100, 53: 100, 52: 100, 51: 100, 50: 90, 49: 90,
                      48: 90, 47: 90, 46: 70, 45: 70, 44: 70, 43: 70, 42: 50,
                      41: 50, 40: 50, 39: 50, 38: 30, 37: 30, 36: 30, 35: 30,
                      34: 15, 33: 15, 32: 1, 31: 1, 30: 0]
    	minVolts = 30
        maxVolts = 60
    } else if(model == "ISW-ZPR1-WP13") {
    	batteryMap = [30: 100, 29: 100, 28: 100, 27: 100, 26: 100, 25: 90, 24: 90, 23: 70,
							  22: 70, 21: 50, 20: 50, 19: 30, 18: 30, 17: 15, 16: 1, 15: 0]
			minVolts = 15
			maxVolts = 30
    } else {
    	result.value = 0
        return result
		if (volts < minVolts)
			volts = minVolts
		else if (volts > maxVolts)
			volts = maxVolts
		result.value = batteryMap[volts]
	return result
private Map getMotionResult(value) {
	log.debug 'motion'
	String descriptionText = value == 'active' ? "{{ device.displayName }} detected motion" : "{{ device.displayName }} motion has stopped"
	return [
			value          : value,
			descriptionText: descriptionText,
			translatable   : true
 * PING is used by Device-Watch in attempt to reach the Device
def ping() {
	return zigbee.readAttribute(zigbee.POWER_CONFIGURATION_CLUSTER, 0x0020) // Read the Battery Level
def refresh() {
	log.debug "refresh called"
	def refreshCmds = zigbee.readAttribute(zigbee.POWER_CONFIGURATION_CLUSTER, 0x0020) +
			zigbee.readAttribute(zigbee.TEMPERATURE_MEASUREMENT_CLUSTER, 0x0000)
	return refreshCmds + zigbee.enrollResponse()
def configure() {
	// Device-Watch allows 2 check-in misses from device + ping (plus 1 min lag time)
	// enrolls with default periodic reporting until newer 5 min interval is confirmed
	sendEvent(name: "checkInterval", value: 2 * 60 * 60 + 1 * 60, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
	// temperature minReportTime 30 seconds, maxReportTime 5 min. Reporting interval if no activity
	// battery minReport 30 seconds, maxReportTime 6 hrs by default
	return refresh() + zigbee.batteryConfig() + zigbee.temperatureConfig(30, 300) // send refresh cmds as part of config
I’m curious if it’s really pet proof up to 100 lbs
I’d like to know if the power of the TriTech can be jacked up to boil the intruder eyeballs like eggs
Unfortunately I can’t help there, I don’t have any pets.
small children? :joy:
FYI these ISW-ZDL1-WP11G / TriTech may stop reporting motion at some non-zero battery. I’ve been using rechargables, and I noticed recently it’s reporting 30% battery and reporting temperature only. But no motion reports since I-don’t-know-when .
Pretty honking big. Still a very cool device and no signs of malfunction. Used in combination with webcore to lengthen the short active duration - there may be another custom device for this purpose. Eventually I will try the DTH “Smartsense Motion Sensor” for local processing, referenced in other Bosch sensor threads but that may only work for WP13 version which is not TriTech.
This could be a contributing factor. Almost all sensors reccomend alkaline batteries only due to the way voltage drops off when running low.
