so the devices -
aeotec multisensor 6- motion -humidity,
fibaro double switch 2 ,bathroom lights ,window lights
Qubino flush shutter DC-bathroom blind
sonoff basic zigbee module - extractor fan
to add sonoff mini diy (for heated mirror with switch )
so the basics ,
when i turn on the shower i would like on high humidity and maybe movement, to close the blinds ( half of me is in front of a window !) turn on the extractor fan , turn off the bathroom lights - turn on the window lights ( light would be in front of the window not behind me causing a shadow ! ) turn on the mirror ( eventually add alexa playing the radio through the bathroom speakers but ok with just asking her for now )
then on low humidity and no movement i want the reverse , to me seems a simple thing ,
nope!
so far i’ve tried adding and stringing some smart-apps together ,lighting- fan controller then created a shower and end shower routine ,
main problem the multisensor 6 , so much steam i cant see my hand in front of my face , won’t trigger on high humidity >70%
it is on permanent power via usb
so shower routine - alexa cant understand it - but by the app ,fan will start - window lights on - blind sometimes 50% mostly dead
end shower routine , fan turns off - window lights turnoff - blind don’t move !
have tried via an app - when blind is @ 100 closed it starts shower routine - nope
really dont wont to have to carry my phone to have a shower or buy additional sensors ( multi 6 ! )
manually operating the blinds works perfectly via a momentary switch,
1 press down 100% close , 1 press up 100 % open same in the device app , and can stop partially
alexa dosent recognise as a blind / shutter … so asking her to close /open wont work,
so the Qubino to me is working
lights and fan work so again the fibaro and sonoff are not the culprits ,
aeotec is a problem, am i not understanding the concept of humidity espec when it can show 100% ?
60 notes on a dud sensor + 20 for the recessor
smartthings routines ? why wont it close the blinds 100% instead of 50 if it moves them and why can’t it open them at all?
bit of a vent and long explanation but truly looking for ideas and help , would have been so much easier to hard wire
guessing either webcore or sharptools may have the answer but tried to keep it locally and as i work away a lot,
not had a great deal of opportunity to start to get my head round them or see if its working
cheers in advance
