Hi amazing community,
some of the automations I have leave out one or the other device now and then (Light does not get turned off, (virtual) switch does not get turned on/off, etc.). I was wondering if anyone else is having the same issues, or if it might be rooted in my own setup?
Detailed setup:
- I have a virtual switch called “Good Night”
- I have an automation, that fires when the switch gets turned on (there are additional conditions on which mode and specific time of the day) --> I use the new ST app to turn on the switch
- The automation is supposed to turn off all lights (Hue local integration, 15 lights), all running Harmony activities, and to change the mode to “Asleep”
- In addition, the automation is supposed to turn of the “Good Night” switch 1 minute later
Issue: every time the automation executes, not all steps/devices are executed. Sometimes it is a lamp that stay on, sometimes the virtual switch does not get turned off again, etc.
It is not always the same devices that fail to execute, and in a few cases the full automation executes.
(As far as I can tell, mode change has always been executed.)
I have a similar automation for the morning, which I also trigger by a virtual switch, which also sometimes does not execute all elements.
Anyone has similar issues or might have an idea why I am experiencing this?
Are there maybe too many devices in the automation? (total of 22 elements in the automation)
Thanks so much for your help in advance!
