Hi, @chrisrose98
With the Rules API you can create flexible and customizable automations. Please, check the example at this post, which describes the following workflow:
- If
Nowis betweenSunsetandSunrise, - Then
Turn Onthe switch device.
For your use-case, the Rule should be modified as following:
"end": {
"time": {
"timeZoneId": "{{yourZoneId}}",
"reference": "Sunrise",
"offset": {
"value": "270", <-- 270 Minutes after Sunrise
"unit": "Minute"
"then": [
"command": {
"devices": [
"{{yourDeviceId}}"
"commands": [
"component": "main",
"capability": "switch",
"command": "on",
"arguments": []
Also, you can find instructions on how to install your Rule at this thread.
