I’m clearly not that up to date on Smart things, but I just read that August smart locks since January 2020 can now integrate into SmartThings without hub.
So I tried setting up my Smart Lock (not the pro) and was able to make the connection (login with my account) to August when adding it to ST. I asked it to be added to a specific room, completed the process and did not find a new “thing” in the room. I tried to re-add and it says I’m already connected.
No lock has been added to my account, at least nothing new appeared. Any ideas?
click on the menu (three bars in the upper left of the screen) and select Devices. See if it shows there. If not, go to Menu then select settings (the cogwheel) and choose Connected Services and remove the August integration and try to add it again.
Thanks for the suggestions. The lock didn’t show up in the devices list. I didn’t know the ‘connected services’ menu existed. I did see the August link, so I deleted it and restarted the app and re-added the August device and am in the same boat again: August link in the connected services but without a lock.
The August Connect Wi-Fi Bridge is needed. There are new August locks that will be to be released this summer that include Connect that is built into the locks
login to IDE @ https://account.smartthings.com go to My Devices and see it is shows there. I doubt it will but worth checking. If not, you should contact August support as they manage the integration.
just curious… if you disable bluetooth on your mobile device, can you still control the lock through your August app
How long did it take to show up. I just got the yrd226cba and it’s connected through the august app and says online, box and manual smartthings compatible. I connect to the app and it says successful but nothing shows up. So confused
Go to the Devices section, click on the Home icon in the upper left of the screen and choose All Devices to see if it shows there. If not, force quit the app and reopen, then look for the lock.
