I have Aqara hub M2. How can I connect it with SmartThings application?
You can only connect Matter devices to your smartthings account if you have a smartthings/Aeotec hub. This is because the communication with Matter Devices, Including Matter bridges, is from the smartthings hub.
So, just having an aqara M2 hub is not enough: you must also have a smartthings/Aeotec hub.
See the community FAQ:
FAQ: What do I need to add a Matter device to the SmartThings app? Do I need a bridge router device?
Did you use smartthings/Aeotec with Aqara? @christian_turner
@JDRoberts
I connected to the China server. Is Aeotec compatible with China connected device?
As long as it’s going to use matter, I think so, but I’m not 100% sure. ![]()
