Smarthings app refuse to connet via Matter the Aqara Hub. Finds it, accepts the qr code but than error 39-519 shows up.
Did you create a matter sharing setup code from the Aqara app? And then in SmartThings App add device, partner devices add, matter, add without qr code, enter setup code
Both qr code and code pairing do not work.
What devices do you have connected to the Aqara hub?
Maybe you can connect them directly to the SmartThings hub?
Temperature sensor, door sensors and cube. I did not try to pair them directly because i want to use the hub (light, alarm) with ST
Contact Aqara support support@aqara.com (They are China timezone.)
