You can rearrange the devices in each room by dragging them, for instance to the top row, and it will save its position and sync it with other phones / tablets.
I’d like to add that device history should show whether the activity was coming from a manual control, external service (list service name), or a routine (list routine name) so that people can debug devices when they turn on /off unexpectedly.
Hi, @Wajo357
I’ve seen cases where users ask if we can know from where a specific event came in but we have received the feedback that it isn’t possible.
A further investigation is needed to check where a command originated from because in the Cloud logs, we can only see something like “switch on” but not what sent such command.
When we have received cases where devices behave strangely, we need to check logs from different sources to see if there’s a trace of the command, so, I think this request wouldn’t have a straightforward path.
Eitherway, I suggest you send this kind of suggestions of improvements to the app to the Customer Support team since they aren’t present in the Community.
