Hi SmartThings team,
I’m reaching out because our API_ONLY SmartThings app is returning this OAuth error during onboarding:
error=max_installs_exceeded&error_description=The+app+cannot+exceed+a+max+of+20+installs
My understanding from the SmartThings OAuth documentation is that OAuth apps should be enabled for up to
500 users by default, so this appears to be the same issue other developers have reported here in the
community.
App details:
App ID: 344255b4-512e-4e5b-a34a-94a1fc164932
App Type: API_ONLY
Classification: CONNECTED_SERVICE
Additional context:
We are onboarding SmartThings accounts into our short-term rental property management platform.
We have already successfully onboarded 22 SmartThings connections on our side, so the 20-install cap
appears inconsistent with our current usage and with the documented default.
- The error occurs after the user authorizes access in SmartThings and is redirected back to our
application.
Could someone please check this app’s install limit and, if needed, set it to the documented default of
500 installations?
Thank you.
