API device command execute?
Hello
I have problem in my air conditioner Display On/Off Command
Unlike other commands, it doesn’t have its own capability. I guess It needs execute command
I found clue on exec capability in logs
So execute capability is
  "commands": {
        "execute": {
            "arguments": [
                    "name": "command",
                    "optional": false,
                    "schema": {
                        "title": "String",
                        "type": "string",
                        "maxLength": 255
                    "name": "args",
                    "optional": true,
                    "schema": {
                        "title": "JsonObject",
                        "type": "object"
My target command is Display_Off like below
"execute": {
                "data": {
                    "value": {
                        "payload": {
                            "rt": [
                                "x.com.samsung.da.mode"
                            "if": [
                                "oic.if.baseline",
                                "oic.if.a"
                            "x.com.samsung.da.supportedModes": [
                                "AIComfort",
                                "Cool",
                                "Dry",
                                "ComfortCooling",
                                "Wind"
                            "x.com.samsung.da.modes": [
                                "ComfortCooling"
                            "x.com.samsung.da.options": [
                                "DiagnosisAI_Off",
                                "Display_On",
                                "ProgressDiagnosisAI_1",
                    "data": {
                        "href": "/mode/vs/0"
                    "timestamp": "2021-08-01T00:23:20.046Z"
So I designed APi Body like below, but not working
    "commands": [
            "component": "main",
            "capability": "execute",
            "command": "execute",
            "arguments": [
                "Display_Off"
Could you give me advice for that? I guess “x.com.samsung.da.options” should be placed at some point but I have no clue.
Welcome to the SmartThings Community, @TonyKim87!
Take a look at the solution shared in the post below. Let me know how it went!
Wonderful!
