will not work no matter what. I can get other commands like “list devices” to work just fine, however whenever I try to properly send this one to list available commands for the device I receive this error
“requestId”: “61232A54-2134-436E-8BE1-FB6754C318B8”,
“error”: {
“code”: “ConstraintViolationError”,
“message”: “The request is malformed.”,
“details”: [
“code”: “BodyMalformedError”,
“target”: “httpRequestBody”,
“message”: “The request body is malformed and cannot be processed by server.”,
“details”:
A POST to that URL is for executing commands on the device not for listing them. The commands are defined by the capabilities of the device so you should already know what they are.
The API is expecting a JSON body defining the command you want to issue and either not getting one or getting one that doesn’t make sense.
I just worked through this exact problem. I am however having trouble with my GoControl garage door controller. I get a response of 200 but nothing happens. Very weird and hard to trouble shoot since I’m sending all commands via Tasker.
The best way is to read the API documentation. The particular details in this case are at:
More generally though, I do recommend you read through the developer documentation and the API reference as it does help you get a better idea of how stuff fits together.
It was a bit easier when I started as there was less of a disconnect between end users and developers.
