Any light switches for 2 wire that work direct with ST, no extra hub?
Hello, could I ask you HOW you connected your Yagusmart light switches? We’ve just installed a single and a double gang. They both work OK manually but our SmartThings hub does not find them.
Same here…in respect of the 2 gang switch…my 1 gang switch was discovered as a ‘Thing’ which I then changed (as referred to above).
EDIT: I managed to pair the 2 gang switch. I held down one of the switch buttons for about 5/6 seconds until it started flashing. Then when I searched for nearby devices on the SmartThings app, it added the switch as a ‘Thing’. In then changed the ‘Thing’ to a Zigbee Multi Switch in the SmartThings IDE which then resulted in a parent and child switch in the app, both of which worked as expected.
Hi all - do the Yagusmart switches or with as well as without the Neutral wire?
My house was rewired 5 years ago, so I think all of the light switches have a neutral
Thanks, Nick
