Android Update 9-19
Crashes are gone +1
Loading faster +1
Status accuracy of devices on start good+1
Mobile location way better on non-hub locations +1
Slider fidelity a bit rough need unit incremental - 1 but +1 for having sliders.
Go ST!
My mobile presence was working great until this morning when it set my mode away but I was only on the other end of the house, my hub is located on the other side. I’ll try to set up the geofence again.
The biggest problem I’m still running into is majorly slow response for the app to update when I turn someone on.
For instance if I tap on an outlet to turn it on it changes from a white circle with “off” to a white circle with “turningon” written on it. It’ll sit like this for a long, long time. Sometimes if I open the setting page for this tile it’ll show as on with the green circle. If I backup then sometimes the tile will show green with ‘on’, sometimes it’ll still be white with ‘turningon’.
One other thing I noticed, if I change my icon to something else, but then tap the tile to turn on or off a device when it’s in that ‘turningon’ or ‘turningoff’ state, it shows the default icon, not the new icon I selected.
I had a weird thing happen last Friday and this is something I’m not blaming on the ST app but it’s the only app I recently updated. I had it set up to do the mode change based on my mobile presence. My S4 wouldn’t wake up and I had to resort a battery pull. This happened twice that day and the only real significant that I remember being different is I was receiving mode changes notification and also getting notification of the open/close status of my multi sensor. I disabled the notification of mode changes and my phone hasn’t locked up since. Coincidence? Maybe, I just thought I’d post this, maybe someone else has encountered it.
