Please keep this thread limited to specific issues. Any comments should be directed to the thread above. Report each issue as a separate reply with this format:
Phone Model:
Phone OS:
Phone OS Version:
Issue or Bug:
Phone Models: Nexus 5, Nexus 7
Phone OS: stock AOSP
Phone OS Version: 4.4.4, 5.1.1
Issue or Bug: Tiny, unreadable SECONDARY_CONTROL text bug that was introduced in 2.1.0 is still partially broken⦠e.g.,
Smart Energy Switch = is now OK *
Z-Wave Contact Sensor = still NOK
Mobile Presence (ST Arrival Sensor) = still NOK
*EDIT Smart Energy Switch is not fixed after all. It was a coincidence when I checked it that it was at 14 watts and looked okay. As soon as it got to 3 digits or more, it was too small to read.
Phone Model: Samsung Galaxy S6
Phone OS: Android
Phone OS Version: 6.0.1 (Marshmallow)
Issue or Bug: When creating rules in various smart apps (tried RM and Button Controller) if you select the back arrow to edit a previous page before going through the entire setup you get a red banner saying āAn unexpected error occurredā, completing the setup seems to work fine.
Phone Model:sm-n920v (Note 5)
Phone OS:android
Phone OS Version:5.1.1
Issue or Bug: smart lighting, an unexpected error occured
Create a new automation, on the very last page (where the automation is renamed), click back instead of done. The automation will be permanently corrupted, and cannot be saved.
Phone Model: Asus Zenfone, Nexus 4,5,7
Phone OS: Android
Phone OS Version: 5.0 & 6.0.1
Issue or Bug: Tiny Text or Text not rendering properly (not aligned) in DTH
Phone OS:android
Issue or Bug: SHM, an unexpected error occured
Create a new custom monitoring rule, click back on the āset up what should happenā¦ā page. The monitoring rule will be permanently corrupted and cannot be saved.
Phone Model: Samsung S6
Phone OS: Android
Issue or Bug: Creating a rule, selected back and still get the Red - Unexpected error has occurred
This issue has existed since at least v2.0.7. Previously, it would randomly line-wrap and cause the second line of text to be cutoff by the boundary of the tile. Now however, it only seems to happen if there is an embedded space in the label text (see before and after examples, below).
Phone Model: Samsung S5
Phone OS version: Android 5.1.1
Issue or Bug: Z-Wave repair.
Z-Wave repair donāt show when it is completed. Phone just showing spinning circle, while ide is indicating repair completed after 3-4 minutes. Started with version 2.1.0.
Phone Model: Motorola Droid MaXX
Phone OS: android
Issue or Bug: Cannot load Smart app view from side menu. EVER - I also reported this issue on 2.1.0
Number one issue for me is trying to load Smartapps from the Hamburger Menu. as per 2.1.0 this never loads⦠I am using Android 4.4 and Android 5.1.1 on Visual Studio Emulator for Android
Phone Model: Samsung SPH-L300
Phone OS: Android
Phone OS Version: 4.1.2
Issue or Bug: āUnfortunately, Smartthings has stoppedā ERROR every single time i try to open the program.
After updating it STOPPED WORKING COMPLETELY.
Uninstalled and reinstalled many times. Reset phone many times.
CANNOT USE SMART THINGS AT ALL
Sent āReportsā every time it happened. Waste of time and house has no control, no security, no monitoring etc nowā¦
Phone Model:GS7
Phone OS: Android
Phone OS Version:6.0.1
Issue or Bug: SHM Custom- Audio Notification -āor play this station or radioā corrupts the child instance.
