Hello I have followed the instructions and i can see it on my ST and i cannot get it to do anything. It says Active but when i try and look at the camera it says Camera not available and i have it wired right now in the same room with my hub. Please advise. Thanks. I have the IP2M 841
As I suggested in the other post, try using port 80 instead of 37777 if you are using a local IP and let me know how you make out. I will try to help as much as I can.
Thanks Belgarion, sorry but i am fairly new to this. i read the post all the way through and i just tried 80 as i did before and it didn’t work for me either. this is how my device page looks
Amcrest Cam-2 Device Amcrest Cam-2 Public
Name Amcrest Cam-2
Label Amcrest Cam-2 Public
Type Amcrest Camera
Version Published
Device Network Id C0A8011A:9391
Status ACTIVE
Hub Home Hub
Group Pool
Last Activity At 2016-06-01 8:47 PM CDT
Date Created 2016-06-01 8:47 PM CDT
Last Updated 2016-06-02 2:28 PM CDT
Data No data found for device
Current States
switch: on
hubactionMode: local
streamType: RTSP
Preferences (edit)
Name Type Value
camChannel range: 0…9 0
camDebug bool false
camIP string 192.168.1.26
camPassword password ****************
camPort string 80
camUser string ladams62
Events List Events
In Use By
S T APP
Name: Amcrest Cam-2 Public
Hostname or IP : i put my ip in
Port: 80
Acct Username: I used what i signed up for the Amcrest Site
Acct Password: Again same as i used to sign up for Amcrest
Video Channel: 0
Camera Debug Mode : off
I had the mode on as well but same thing.
when i click the play button where it says active in the top right corner it says connecting and becomes green for a few seconds, then white, then back to active white and then in the middle of the screen it says camera unavailable.
is there anything that i need to do with their site before this will work as i can see the camera but even on their page the pan and tilt is not responding? thanks for any input and sorry to load you up with all of the information
When you type in your local IP (192.168.1.26, based on the “camIP” parameter in your post) in the “Search or type URL” box, it should look like this:
The dialog box is where you should type in your username (should be an administrator level user account) and password. If they do not work, then that would be the first problem. If they do, you should see a screen with a live stream of the camera and the following commands above the view window:
If you got this far, click on “Setup”, then click on “Network” in the left side of the screen, then “Connection” and tell me (or do a Snipping Tool capture) what you see.
Let’s put ST on the back burner for a sec, have you ever even seen your camera give you a video display through the web browser using the Amcrest Web View that @Belgarion is asking you about? Your responses above don’t seem like you have
I gave the sceen to him and he did it remotely. I do know that they reset everything, camera and site. I think i will go in and delete everything from the IDE and start over since that’s pretty much what they did to get it up and running with them.
Tried to delete from ide and start over and now its saying i am not arthorized. and i have been denied access.Any Suggestions on how to get it back on ST. Thanks for the Help
Thanks for your help. I guess i should have left well enough alone. when i click om my device handler and then belgarion amcrest camera it says access denied.
I wish there was a way that i can have St to identify it in the Marketplace
