Amazon Echo Turning On Lights at 25%
Good idea opening the case with support. This looks like an issue with the Echo integration. If you just tell Alexa to turn on/off, then you shouldn’t see setLevel entries in the logs at all. It looks like when turning off its sending the level to 0, which isn’t good either.
